Quick question about Outlook and Nokias
Discussion in 'Mobile Phones Forum' started by Delta07, Jan 16, 2008.
Tags:
  1. Delta07
    Delta07
    This is really doing my nut in now so if anyone can answer this then I can go sleep! :p
    Do all Nokia phones sync with Outlook. If so is it easy.
    Simple yes or no's will do fine. :)
    basically looking for the cheapest Nokia that will sync.
  2. Andy98765
    Andy98765
    Feb 15, 2006
    10,472
    2
    +1,365
    Not every Nokia will sync, the super budget ones will not.
    Go to the Nokia site and look at software downloads and check against the models you like to see if sync software is available. But in general all the bluetooth ones do. All I got was a bluetooth USB dongle and plugged it into my PC, linked the Nokia to it (paired), loaded the software, setup what I wanted to sync and that was it.
  3. Delta07
    Delta07
  4. Uridium
    Uridium
    Jan 29, 2005
    14,434
    North West Leicestershire
    +1,855
    Remember that Nokia's will only Sync Outlook Tasks, Calendar, notes and contacts NOT Outlook Email.
    Only way of getting Outlook Email is with the Nokia Mail for exchange app on some N and E series phones. As the name suggests thouh this only sync's with an Exchange server not an email PST.
  5. Delta07
    Delta07
    Thanks for the info. Contacts is really my main reason for wanting syncing, tasks are a big bonus :D
    I am looking at the Nokia 2630, but expansys are about £30 more expensive that buying it on O2 (I have to buy from expansys). Is it worth £80?
    Anyone know if the Benq-Siemens will work (data services) on O2 UK?
