iendicott
Established Member
Have a look at this case http://www.ebuyer.com/customer/prod...2hvd19wcm9kdWN0X2dhbGxlcnk=&product_uid=93403
The rear view where you can see where the ports on the motherboard pop out the case
Now look at this image of the motherboard http://image2.sina.com.cn/IT/h/2006-06-23/76cc536dcf61ccadf14660d5dcfa214e.jpg
Now the ports on the motherboard don't line up against the case pre drilled holes, so if the part on the case with the ports come up removable so you can put pretty much any motherboard into it ?
Thanks Ivan
Thanks Ivan
