quick question about lip sync
Discussion in 'Plasma TVs' started by Rich, Feb 8, 2003.
  1. Rich
    Rich
    Sep 15, 2002
    2,239
    warrington
    +134
    some channels on sky digital(sky sports 1,sky news,and others) have worse lip sync problems than other channels.
    I notice that on my sky signal test,signal strength is about 40% and signal quality is about 50%,my friend has over 80% for both
    Could anyone tell me,if i get my sky dish better aligned,will it cure my lip sync problems,or at least improve it ?
    i know plasmas do have a slight problem,i don't really notice any problem on most channels,but the bad channels on my screen are really badly out of sync. i've a 37" panasonic with a JS box.
  2. StooMonster
    StooMonster
    Nov 20, 2002
    4,970
    Kent
    +314
    No it will not.
    I've noticed that lip sync issue also varies by programme, outside broadcasts like Question Time can be the worst. Also programmes that were originally shot in NTSC video and converted to PAL can be very bad.
    Plasma just compounds a problem that is already there in the transmission.
    Only way to fix it is to delay the audio, either though your amp (if it supports delays) or through a dedicated digital delay box [see the thread].
    StooMonster
  3. Rich
    Rich
    Sep 15, 2002
    2,239
    warrington
    +134
    i have the panasonic matching speakers for my screen for convience(i didn't want to turn on my amp every time i watched TV),if i got a digital delay unit i would have to adjust it for every channel i watch.some of my channels work fine but some are really bad
  4. delta
    delta
    Oct 16, 2000
    469
    16
    North East Cheshire
    I've noticed a delay on some Sky broadcasts, eg, yesterday, very slight but noticable on Grandstand on BBC1. It never occurs on Freeview though. (Both inputs pass through TiVo).
