quick question about hd connectivity
londonguy1973
Hi guys,
Im looking around at amps/dvd players to upgrade my system but am a bit confused about hd connections. As i understand it its best to connect the dvd player straight to the tele using hd cable? But is it best to also connect the player to the amp using hd? or would you only need audio connection between the two?
Do you also connect the amp to the tele someway? or is that standalone for the audio?
probably an easy question for most of you but im all confused by it
cheers
