Quick Question 4 users who have upgraded HDD on Pace
Discussion in 'Digital TV & Video Players & Recorders' started by SoapyBible, May 31, 2004.
Tags:
  1. SoapyBible
    SoapyBible
    I have got a Pace twin with the original software on it today plus I have a 60gig harddrive to put in it mht2060at. Question is...
    Is it safe to put the harddisk in before the planned software download this weekend or should I wait until after.
    I am planning to piggyback the new drive to try and keep warranty intact.
    Thanks.
  2. simonb68
    simonb68
    Dec 16, 2002
    229
    Bucks
    +3
    Shouldn't be a problem doing it before, I've done an update with an upgraded HDD (as have many others I'm sure), it worked fine. If you're going to piggy back it then if you get problems with the update it should be easy enough to remove it to test if this is what is causing the problem.
