quick pw7 question
Discussion in 'Plasma TVs' started by chedmaster, Apr 28, 2005.
  1. chedmaster
    chedmaster
    Jan 29, 2005
    2,654
    68
    +28
    looking at buying a 37" pw7, my dad has a wall mounted pw4 and spare table top stand from when he bought it, will it fit? (was for a 42" thinking about it, so prob not!)
  2. MAW
    MAW
    Jan 24, 2002
    14,082
    Nr Dorking
    +412
    Actually it probably will fit. Have a look at it, if it has 2 sets of holes for mounting the little legs, it will fit.
  3. chedmaster
    chedmaster
    Jan 29, 2005
    2,654
    68
    +28
    yeah it does, that saves me some money! thanks a lot.
  4. MAW
    MAW
    Jan 24, 2002
    14,082
    Nr Dorking
    +412
    You just move the posts/legs to the inside holes, the outers fit 42/50", the innners, 37". Easy innit?
