Quick PE50 question.
Discussion in 'Plasma TVs Forum' started by dognuts, Jun 18, 2005.
  1. dognuts
    dognuts
    Feb 13, 2005
    444
    +26
    Hi all,
    Just wondering if anyone knows how to find out how long the screen has been running for.
    Im not particularly bothered about damaging the screen after reading all the "panasonic bombproof :smashin: " quotes on here but i just wanted to see out of curiosity.
    Thanks.
  2. Jazz Monkey Jr
    Jazz Monkey Jr
    Jan 10, 2005
    14,194
    2
    4
    137
    Garstang, Lancs
    +1,625
    Here is how it is got into.
    turn to channel 99
    bass to max.
    treble to min.
    then press v/- 0n front panel at the same time as index on remote.
    this is service one.
    press the green button on the remote to cycle through the options untill you can go no further
    then press hold on remote.
    service two should now be showing.
    press the green button and cycle through the options untill you get to the option that says hours used or some thing like that, not sure of exact wording. the value displayed is how many hours it has been on.
    words of advise
    do not change or alter any thing in these menus unless you are absolutly sure of what you are doing.
    You can do some serious damage to your plasma if you are not carefull.
    to get out of the service menu press exit on remote. if that does not work turn the plasma off ten back on again and you should be out of it.
    I take no responsability for any problems caused by entering the service menu
  3. dognuts
    dognuts
    Feb 13, 2005
    444
    +26
    Thanks for the info but i couldnt get it to work.
    I get to the end of pressing the green button,press hold and nothing happens.
    Ah well,no problem.
    Thanks again.
