quick network question from newbie
Discussion in 'Desktop & Laptop Computers Forum' started by newstuart, Jun 18, 2005.
  1. newstuart
    newstuart
    Apr 22, 2004
    1,794
    Northumberland
    +82
    Ok, probally best explaining my aims first,
    I have 2 MCE PCs in the house one in living room and one in bedroom, The one in the living room is connected to a Telewest broadband modem also in the living room. the one in the bedroom has no broadband at present. what i want to achieve is,
    1) to be able to access internet on both PCs
    2) to be able to access the hardrive on the PC in the bedroom from the pc in the living room.
    I have pre wired a cat 5 network cable between both rooms. and both PCs have a lan network connection but the one in the living room has the broadband plugged into this
    I think a need a router ? (sorry first dealings with networks!) I have heard talk of different kinds of routers depending on the broadband connection so what do i need ? (I have no need for wireless connections at all)
    Think that covers it but any questrions please ask
  2. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
  3. Rambles
    Rambles
    Jul 14, 2004
    8,125
    UK
    +1,096
    I just bought this router/modem here.
    It has 4 ethernet ports so can work with up to four devices and each has independent access to the internet. So you only have to have the device you are using switched on....
    Routers are the best option as they also provide hardware firewalls, and other security measures.
    However....... you could just connect the two PC's with a crossover network cable and enable internet connection sharing, that will work fine too. I did that for about a year and never had any problems, only switched to a router to add a third device to the network.
  4. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    lisa same one as i have at home my 4th linksys started of with a BEFSR41 that i paid £140 4 years ago :eek:
  5. newstuart
    newstuart
    Apr 22, 2004
    1,794
    Northumberland
    +82
    could you please explain how you connected the 2 pcs using a crossover cable ? the living room pc (the one that has the broadband connection) only has 1 LAN point which at present has the broadband modem plugged into it
  6. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    you would need to fit an extra NIC in that case much better to get a router mate if £30 is putting you off i picked up a netgear seconhand on the forum for £10 and was offered a linksys for £15
  7. newstuart
    newstuart
    Apr 22, 2004
    1,794
    Northumberland
    +82
    thanks for the advice ill get looking on here now
  8. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    crocodile had a linksys for sale, see if he still has it...
  9. Rambles
    Rambles
    Jul 14, 2004
    8,125
    UK
    +1,096
    Great minds think alike...... ;)
  10. newstuart
    newstuart
    Apr 22, 2004
    1,794
    Northumberland
    +82
    Just got one of these from ebay for £20 including P&P, i didnt really need wireless but guess i may in the future, Hoping these are ok ? read a few reviews quickly before i bid
    linksys wirless broadband router befw11s4
