Quick k750i question
Discussion in 'Mobile Phones Forum' started by Jazz Monkey Jr, Sep 23, 2005.
  1. Jazz Monkey Jr
    Jazz Monkey Jr
    Jan 10, 2005
    14,061
    2
    4
    137
    Garstang, Lancs
    +1,597
    I can't get the predictive text on my phone to work, there isn't the option for the T9 input anywhere, help.
    Mal
  2. Gizmo 76
    Gizmo 76
    Aug 17, 2003
    2,233
    116
    The Apps are Calling :-S
    +522
    Press and Hold the * Key turns T9 on and off :smashin:
  3. Jazz Monkey Jr
    Jazz Monkey Jr
    Jan 10, 2005
    14,061
    2
    4
    137
    Garstang, Lancs
    +1,597
    I tried that, do you hold it while writing a message?
  4. tjdewalt
    tjdewalt
    May 17, 2005
    23
    4
    when you are in the message field, you can hold * for a while and the T9 Icon will apear. If you hold it again, the icon will go away...
  5. Jazz Monkey Jr
    Jazz Monkey Jr
    Jan 10, 2005
    14,061
    2
    4
    137
    Garstang, Lancs
    +1,597
    It doesn't work, in the settings there is no English laguage to select. Only Frence, Arabic, standard abc etc. The predictive text will work when selecting French or arabic but there is no english installed on it.
