Quick help needed, PW6 and DTS1 stand
Discussion in 'Plasma TVs Forum' started by Koalaboy, Oct 23, 2004.
  1. Koalaboy
    Koalaboy
    Oct 19, 2004
    276
    28
    Plymouth, Devon
    +31
    My panny pw6 has just arrived, and I'm building the avsales DTS1 stand that I got with it.
    It has two sets of spacers and fixing screws, and I have to decide which ones.
    So the question to anyone that has built such a combination before..
    H1 or H2 spacer, L1 or L2 mounting screws. long or short. ???
    :lease:
    Someone must have done this before.
    Michael.
    Edit: I just tried it with the large of both, and it seems to be fine. Please correct me if this will break anything :lesson:
  2. Fatti
    Fatti
    Oct 22, 2002
    665
    Worcester
    +40
    It's been a month or so since I put ours together, and if I remember correctly I ended up using the shorter spacers and screws. As it 'stands', the uprights of the stand are now about 4 to 5mm from the back of the panel.
    I seem to recall that the standard pedestal mount supplied by av-sales showed up as being for Panasonic and a.n. other manufacturer - cant remember which. Probably find the fixing positions on a.n. other panel are more recessed and need the longer spacers and screws.
  3. splobber
    splobber
    Apr 8, 2003
    174
    +12
    Funnily enough I was faced with the same situation last night.
    I used the shorter screws and spacers in the end as they were a better match to the screws that was already on the back of the screen.
    Nothing has come crashing to the ground as yet. :smashin:
