Quick Harmony 895 question
chaosss
On this remote can you group components for a particular zone, i.e. set it up so you first select the zone you are in then it shows the appropriate components for that zone?
Asking as I am thinking of using one in a multi room environment.
clockworks
No
Unfortunately, the activities list only has one level. You'd need to set up 2 pages of activities, but it would always default to page 1.
To do this properly means buying a Pronto.
T800
You could use it in two different rooms if you have different activities like this:
Watch DVD Room A
Watch Sky Room A
Watch DVD Room B
Play Xbox 360 Room B
Do you need to have two seperate zones or can they all be on the front page ?
