Quick fix for new TV on Harmony One wanted.
Discussion in 'Home Cinema Control & Remote Controls' started by newth, Jan 9, 2012.
  1. newth
    newth
    Oct 25, 2010
    29
    3
    Hi guys, I'm sure this must be easy, but it's been over a year I think since I last had to touch the programming software for my Harmony one.
    I've just got a new TV. Is there a quick easy way to swap it over or do I need to edit each activity?
    I've added the new TV as a device - I could remember that bit!
    Newth.
  2. logiciel
    logiciel
    Feb 2, 2008
    52,974
    UK
    +5,718
    Hi - remove the previous TV device and each activity will then prompt you for the new one.
  3. newth
    newth
    Oct 25, 2010
    29
    3
    Thank-you. That's great. I'll give it a go at the weekend.
  4. logiciel
    logiciel
    Feb 2, 2008
    52,974
    UK
    +5,718
    :thumbsup:
