Quick electrical / conduit question
Discussion in 'General Chat' started by jaipal2004, Dec 29, 2016.
  1. jaipal2004
    jaipal2004
    Feb 14, 2009
    2,430
    Walsall
    +218
    just finishing up the re-purposing of a space into a utility room and have gone for the utilitarian look (visible copper and steel)
    I'm adding some lights and sockets and using metal conduit to do this....
    How do I terminate the 20mm metal conduit pipes with a light holder? Can't see anything other than plastic and that will look silly against the metal and copper.
    Ideally want to avoid spray painting plastic fittings etc and want a clean look.
    Screwfix / Amazon links would be greatly appreciated!
    thanks in advance
  2. maxwell
    maxwell
    Apr 27, 2008
    3,033
    +3,229
  3. jaipal2004
    jaipal2004
    Feb 14, 2009
    2,430
    Walsall
    +218
  4. wilbanat
    wilbanat
    Sep 25, 2009
    7,668
    +9,542
    Beezer Box :smashin:
    Standard light fittings screw straight on (the holes line up)
    • Like Like x 1
    • Agree Agree x 1
    • List
  5. MartinMiller
    MartinMiller
    Oct 12, 2007
    2,083
    116
    Hamilton, South Lanarkshire
    +655
    Could've wired the lights in bare copper micc cable
  6. jaipal2004
    jaipal2004
    Feb 14, 2009
    2,430
    Walsall
    +218
    I presume I'd need to use the plastic fittings?
  7. wilbanat
    wilbanat
    Sep 25, 2009
    7,668
    +9,542
    I don't follow, fittings for what ?
    Conduit > beezer box > light fitting
  8. jaipal2004
    jaipal2004
    Feb 14, 2009
    2,430
    Walsall
    +218
    Sorry.... Should've explained that this is a new DIY foray for me.
    By light fitting, I write have to use one of these plastic ones? .....
    British General Batten Lamp Holder White
  9. wilbanat
    wilbanat
    Sep 25, 2009
    7,668
    +9,542
    Oh I see, well yes that would work but sure there are some more in keeping with the look you are going with.
  10. jaipal2004
    jaipal2004
    Feb 14, 2009
    2,430
    Walsall
    +218
    Thanks mate
    I'll check on a few other sites... Couldn't find anything on Screwfix as yet :/
  11. wilbanat
    wilbanat
    Sep 25, 2009
    7,668
    +9,542
    These would work well
  12. jaipal2004
    jaipal2004
    Feb 14, 2009
    2,430
    Walsall
    +218
    Great...... I'll check
    Thanks again!!
  13. Sonic67
    Sonic67
    Sep 14, 2006
    45,553
    11
    167
    Home
    +24,234
    As above,
    something like that.
    Then the light should attach to the two screw threads with the right screws.
    • Like Like x 1
    • Agree Agree x 1
    • List
  14. wilbanat
    wilbanat
    Sep 25, 2009
    7,668
    +9,542
    Search for Bulkhead light
  15. wilbanat
    wilbanat
    Sep 25, 2009
    7,668
    +9,542
    M4's I believe.
  16. sparkie1984
    sparkie1984
    Feb 21, 2010
    7,826
    +3,059
    Exactly what I was about to say!
    I love doing metal conduit, if done right it's very neat and satisfying unlike that pvc crap!
    • Like Like x 1
    • Agree Agree x 1
    • List
  17. jaipal2004
    jaipal2004
    Feb 14, 2009
    2,430
    Walsall
    +218
    Started it today.... Very satisfying but a pain threading wire thru it if you have a few turns!
    Couldn't find any local shops selling metal look lamp holders so going for bulkhead lights as recommended above.
    Thanks for all the advice :)
  18. its_all_Greek
    its_all_Greek
    May 8, 2009
    4,765
    Nottingham
    +2,589
    Are you not using inspection bends, or inspection boxes anywhere?
  19. sparkie1984
    sparkie1984
    Feb 21, 2010
    7,826
    +3,059
    Id recommend buying a draw tape. That's what is used to push through then tape the cables onto the end.
    Inspection bends are for amateurs :p (yes I know it's a DIY job)
  20. jaipal2004
    jaipal2004
    Feb 14, 2009
    2,430
    Walsall
    +218
    Used inspection bends so I wouldn't need to use pipe benders but still difficult to pull the wire through - think the wire is possibly too thick and therefore not easily bent.
    Will use draw string next time - managed to do what I needed for the time being!
    Still struggling to find suitable bulkhead light from the likes of Screwfix / CEF etc or even a grey lamp holder for putting straight on the beezer box.
    Thanks again all!
  21. its_all_Greek
    its_all_Greek
    May 8, 2009
    4,765
    Nottingham
    +2,589
    I'm assuming your using singles and not twin and earth or flex?
    Are you staggering your cables or just taping them all together in a large bunch?
    i.e. Attach 1 to your draw tape, 5cm later connect your second to the first, then 5 cm later your third to your second etc.
    Have a look for Bulk head fittings, these will have a 20mm knock out for Conduit
    [​IMG]
  22. sparkie1984
    sparkie1984
    Feb 21, 2010
    7,826
    +3,059
    I would assume as it's DIY he's used twin and earth also make sure the conduit is earthed, being metal if a fault occurs it could become live
  23. its_all_Greek
    its_all_Greek
    May 8, 2009
    4,765
    Nottingham
    +2,589
    If it is T&E no wonder he's struggling, good shout with the earthing though
  24. sparkie1984
    sparkie1984
    Feb 21, 2010
    7,826
    +3,059
    I may be mistaken but just thinking if it's a diy job he may not know about singles. Wouldn't want to be pulling much twin and earth round it
  25. jaipal2004
    jaipal2004
    Feb 14, 2009
    2,430
    Walsall
    +218
    Yep... Using twin and earth and have been sure to earth correctly :)
    Ta
  26. jaipal2004
    jaipal2004
    Feb 14, 2009
    2,430
    Walsall
    +218
    Singles?? Do tell..... :)
  27. sparkie1984
    sparkie1984
    Feb 21, 2010
    7,826
    +3,059
    Generally when you wire circuits through conduit you use single cables, which is where the individual conductors are on their own (so you have a brown, blue and green/yellow cable one their own) due to the bending of the conduit and the cables rigidity it can be very difficult to pull a twin and earth cable through, as you've no doubt found out! :)
    It also offers the benefits of picking and choosing how many of what cable you need, for example in a multiple switch arrangement it makes wiring the switching far easier than having to drag multiple core cables between the switches. The thing is that to use singles the conduit has to terminate properly into an enclosure, due to the single insulation the cables cannot run "freely" like you could clip a twin and earth, you cannot with single cables.
    Whereas twin and earth has the benefit of insulated conductors and an additional layer of insulation over them all. (apart from the earth, which is why you put earth sleeving over it when your terminating it)
  28. jaipal2004
    jaipal2004
    Feb 14, 2009
    2,430
    Walsall
    +218
    Makes sense. I should've guessed!! D'oh :)
    I presume I could've cheated and unsheathed the twin and earth giving me singles? Although I presume it can be purchased as such from Screwfix? What would I search for?
    Thanks again!
  29. sparkie1984
    sparkie1984
    Feb 21, 2010
    7,826
    +3,059
    Problem with that is the earth would have no protection on it and putting earth sleeving on a long length of it would be a nightmare.
    It is something like this: 6491 X Single Core Pvc Conduit Wire | City Electrical Factors. But it will work out dearer than twin and earth as you'll have to buy brown, blue and earth cables
    Size depends on what you're using it for and what circuit protection you have, generally 1.5mm for lighting and 2.5 for sockets
  30. IronGiant
    IronGiant
    Jun 7, 2003
    65,908
    +45,911
    conduit cable e.g: Conduit Wiring Cable 6491X 1-Core 1.5mm² x 100m Green/Yellow
    Other colours are available ;)
    There's a better range (both sizes) at toolstation:
    Toolstation
    Probably worth finding out the prices at CEF as sparkie linked to, as prices may be even better.
    • Like Like x 1
    • Thanks Thanks x 1
    • List
