Quick Denon 500 question
Discussion in 'Home Cinema Buying & Building' started by Shooter1, May 10, 2005.
  1. Shooter1
    Shooter1
    Feb 15, 2005
    2,180
    +140
    I'm about to buy the Denon 500 based on all the good reviews :thumbsup: . I will be combining this with a Sammy 50" DLP and Sky plus.
    I'm just about to order good quality cables. Can you please confirm that the following will do the trick.
    1. Scart for Sky Plus to TV.
    2. Optical Cable for Sky Plus to Denon.
    3. Component for Denon to TV.
    Do I need another scart for Denon to TV & do I need phono leads? If the answer to either of these is yes, can you please explain why.
    Sorry for the newbie questions, but I thought I may as well get it right 1st time :D
  2. Judders
    Judders
    Oct 31, 2004
    154
    16
    Basingstoke
    That's exactly how I have mine connected. It'll do the job just fine. :thumbsup:
    I did have another scart going from the LCD to the Denon, but you don't need it unless you're going to use your TV's built in tuner - which I'm not - and want to the Denon to take a sound input from it. I watch everything via Sky+ nowadays as the picture quality's much better. :cool:
    HTH
    Jud
  3. Shooter1
    Shooter1
    Feb 15, 2005
    2,180
    +140
    Thx Judders, greatly appreciated.
  4. reddux
    reddux
    Mar 6, 2005
    If you will be connecting a PS2 or Xbox you may want to invest in some phono leads too as I needed the component connection from my PS2 for viewing on the TV (with no component input on Denon) as any lesser connection method was very poor PQ and wanted the sound through the Denon aswell ;)
  5. Shooter1
    Shooter1
    Feb 15, 2005
    2,180
    +140
    Thanks reddux. I will be connecting an xbox via the hi def cables. Will I still need the phono leads?
  6. Judders
    Judders
    Oct 31, 2004
    154
    16
    Basingstoke
    I have my PS2 (Slimline) and Denon connected via component to my LCD using one of these: Component switch box
    I also had to buy a PS2 component cable (sorry if that's stating the obvious!).
    And My Sky+ and PS2 connected via optical to my Denon 500 using one of these Optical splitter
    All works a treat with great sound and PQ :thumbsup: Playing Splinter Cell: Chaos Theory at the moment and the use of the surround speakers is very cool :cool:
    Jud
  7. Judders
    Judders
    Oct 31, 2004
    154
    16
    Basingstoke
    Shooter, when you say Hi-Def cables, do you mean component? If so, you will need to cater for sound, as component cables only carry picture signals.
    I know nothing about the Xbox, but if possible, use an optical connection as I have for my PS2.
    HTH
    Jud
