Quick Denon 3802 set-up prob
Discussion in 'AV Receivers & Amplifiers' started by tee, Mar 19, 2002.
Tags:
  1. tee
    tee
    Sep 17, 2000
    2,711
    71
    Close by
    +50
    Ignore - problem solved!
  2. bob007
    bob007
    tee, Have you selected VCR1 on the amp from the remote control,
    VCR1 should be visible in the LCD window.
    was i right.......?
  3. tee
    tee
    Sep 17, 2000
    2,711
    71
    Close by
    +50
    I don't know :eek: I just changer the optical to opt 2 and changed the output to TV..... I don't know why it worked, but it did??! Anyway I was propbaly doing something wrong after sitting trying to set it up for so long..... my.... head..... hurts.... :D
  4. denonman
    denonman
    AH you got the 3802 did you go for the black or the gold?
  5. tee
    tee
    Sep 17, 2000
    2,711
    71
    Close by
    +50
    Yeah I got one in the end! The gold were just too hard to get hold of and I couldn't wait any longer so I went for black. Glad I did :D
  6. Cheekster
    Cheekster
    Mar 10, 2002
    1,007
    48
    Oxfordshire
    +70
    It was the other way round at the dealer from whom I purchased my Denon 3802. They had an abundance of Gold ones in stock and a back order situation for the Black ones.
    I waited for a black one. :D
    Cheekster.
  7. tee
    tee
    Sep 17, 2000
    2,711
    71
    Close by
    +50
    For a minute I thought you were saying you still had a gold one and you wanted to swap with me! To be honest though, I'm very happy with the black one now - black goes with everything after all :D
