Quick DDR Question
Discussion in 'Computer Components' started by scrapbook, Oct 7, 2004.
  1. scrapbook
    scrapbook
    Jan 12, 2002
    7,422
    +550
    I am running with a Gigabyte GA7S748 MB.
    I have a spare stick of PC2100 RAM, will the system work it I put this into a second DIMM if the first DIMM contains PC2700 RAM?
  2. KraGorn
    KraGorn
    Aug 30, 2003
    4,745
    68
    Warrington
    +27
    As long as the BIOS allows you to select the memory speed and you do so at the lower speed then I see no reason at all why it wouldn't work .. also take care to note the CAS latency and other characteristics of the slower memory strip if dealing with a BIOS that has such detailed settings.
  3. H4r7y
    H4r7y
    Jun 17, 2003
    1,713
    39
    Nottingham
    i used to have a setup like that, and the faster memory just ran at the slower speed.
    ran fine for months mate.
