pxr5
My lad has one of these quick charge kits and one rechargeable white battery pack. One side of the base has never worked, now neither side does. When I turn on the base unit the 2 green lights flash momentarily, but on plugging in the rechargeable battery pack no light come on at all - red or green. I've cleaned all the contacts and the base unit does make that slight noise as it always has - akin to capacitors charging.
Is it a case that the battery pack has simply given up or is the base unit knackered. The whole thing is about 9 months old and the pack has had pretty much continous use since then. I'm loathe to buy another battery pack if they only last this long. Or am I better off with simple rechargeable AA batteries.
