markymiles
So finally thought I'd give it a go and lifted my sofa ready to take measurements etc. I guess that's the end. Shame.
Are you using inner tubes with your build?, I found with just the half balls in place the inner tube was actually lifting the platform up, when weight went on the platform it was causing excursion on the drivers, I ended up putting some 10mm thick timber on the floor for the balls to contact with giving me around 40mm clearance from the floor.
The balls do seem to compress a fair bit on mine. Would be good to see how much the Hudson dome compresses vs the sponge balls.
Good to see another convert!, Added tubes to mine today certainly ramps up the intensity, Saving private Ryan beach scene (with BEQ) is incredible
Question about attenuation, as the NX manual is unclear, I have mine set to 3 o'clock as per the instructions in said manual.
What does it actually do ?
No that is not right, if you do that the signal will clip on the way in (if the max output from the upstream device is more than the input sensitivity of the inuke)Ideally I think it should be set at fully clockwise as this is leaving the signal intact. You then adjust the gain in the dsp settings, assuming you have a DSP version
