Quick BK Antimode question
Discussion in 'Subwoofers' started by Olliefreddie1, Feb 5, 2014.
  1. Olliefreddie1
    Olliefreddie1
    Feb 26, 2012
    213
    43
    +100
    I have the original Antimode.
    Could someone tell me - it's been unplugged for last week and about to be put back in system.
    Will it have retained the calibration settings during this time?
    Many thanks.
  2. fuel2000
    fuel2000
    Apr 8, 2006
    404
    +30
  3. mojogoes
    mojogoes
    Remembered (1961-2016)
    Oct 12, 2007
    10,469
    Faraneverland
    +1,984
    Yep!! just plug it in and it should remember its last setting / s.
  4. Bolander
    Bolander
    Jul 8, 2006
    472
    28
    +59
    Settings resulting from the calibration process will be retained unless a further calibration is carried out. However, if you used the Lift 25 or Lift 35 modes, these will not have been retained unless the setting was stored by holding down the Lifting EQ button until a beep was heard.
