Quick Bi-wiring question.
Discussion in 'AV Receivers & Amplifiers' started by MagicBoy, Jan 6, 2005.
  1. MagicBoy
    MagicBoy
    Sep 19, 2003
    307
    +20
    I've just wandered past the local Richer Sounds and thought "I've always wondered about this bi-wiring thing". So I spent £6 and impulse bought some on some Gale XL160-2 bi-wire cable to give it a try.
    Speakers are Tannoy MX-3M fronts and the amp is a Sony STR-DB790 which has twin sets of speaker terminals (A & B). How do I wire it up - twist the wires together at the amp end and carry on using set A or route (say) HF to the A and LF to the B terminals? Is there likely to be any difference?
  2. MagicBoy
    MagicBoy
    Sep 19, 2003
    307
    +20
    Anyone?
  3. wookie
    wookie
    This is subjective, but for six quid :laugh:
  4. the mechanic
    the mechanic
    Nov 30, 2003
    1,193
    Wrexham,North Wales
    +52
    Hi magicboy,
    As wookie states wire both HF terminals of the speakers to A,and the LF to B (or vice-versa as it does'nt really matter).Remember to remove the bridging links from the teminals on the speakers otherwise it will defeat the whole process of bi-wiring.
    I've done exactly the same on my Mission 773's and they sound more open and controllable then when I had them single wired.
    All you need to do then is switch speakers A and B on and take a listen.I advise fitting banana plugs to the cables so you can switch them around (ie using speakers B for HF,and A for LF to see if it makes a difference to the sound).
    Hope this helps you out, and good luck.
    TTFN
  5. MagicBoy
    MagicBoy
    Sep 19, 2003
    307
    +20
    Thanks guys, I'll give it a try. I've got quite beefy Gale XL315 cable at the moment (which is years old and from the first system I had when I was a student) so I'll see what changes it brings.
    Having had a quick go at stripping some of the wires yesterday I can see banana plugs being a nice idea long term. Where's the best place for reasonably priced quality ones (bearing in mind I'll need 16!) and do they require soldering?
  6. eviljohn2
    eviljohn2
    Jul 8, 2002
    7,529
    Near London.
    +208
  7. the mechanic
    the mechanic
    Nov 30, 2003
    1,193
    Wrexham,North Wales
    +52
