No doubt an easy question for most but its 3am, i'm tired and cannot think...!
TV is a TX-P42GT30 and will be using a Denon 1912 amp. Original plan was to plug the Blu Ray, XBOX and Sky HD box into the amp via HDMI. The gf has had a bit of a moan saying that she won't always want to have sound through the speakers and will be happy with the TV speakers... if everything is going straight into the amp is it possible to by pass it sometimes and just use the normal TV speakers?
Secondly... rather then plugging everything into the amp how would I go about putting it all through the TV first? Could I simply use HDMI to stick everything into the TV and then just use an optical cable to output the sound to the amp? If doing it this way if the amp was turned off would the sound just play out of the TV regardless of the source?
Thanks.
Thanks.
