Quick Arcam DV88 question?
Discussion in 'Blu-ray & DVD Players & Recorders' started by CLH, Jul 19, 2002.
Tags:
  1. CLH
    CLH
    Apr 15, 2002
    2,159
    38
    +21
    Mines coming next week!
    If I set up my defaults to output RGB through scart etc will it change defaults when it changes regions (ie if I put it into auto region mode). OR do I have to set defaults for every region?
  2. Brent Turner
    Brent Turner
    If you set the player to multi region, it'll quite happily switch between regions without changing settings for RGB. If you change regions manually, that also changes the scart output and you end up with a nice green picture and the need to change things back.
    Multi region handles RCE no problems. Played well over 300 discs on this player with no region problems.
  3. Jasonjo
    Jasonjo
    Dec 3, 2001
    2,688
    UK
    +116
  4. Jasonjo
    Jasonjo
    Dec 3, 2001
    2,688
    UK
    +116
  5. Jasonjo
    Jasonjo
    Dec 3, 2001
    2,688
    UK
    +116
    P.S. Hope you enjoy the player...:D
  6. CLH
    CLH
    Apr 15, 2002
    2,159
    38
    +21
    cheers for the help! Looking forward to this now!
