Quick answer needed - daft question?
Discussion in 'Movie Forum' started by The Spaniard, Nov 27, 2003.
  1. The Spaniard
    The Spaniard
    Jan 2, 2001
    1,105
    Walsall
    +80
    Hi Guys,
    I have a pioneer 737 multi region dvd player - to date I have only ordered and played regions 1 & 2. Currently considering Terminator 3 on region 3 due to price!
    Will I be able to play it and are there any other factors to consider?
  2. Nike
    Nike
    Feb 27, 2001
    667
    bournemouth, UK.
    +20
    There's no reason why it shouldnt.
    If you can play R1 OK, then you know you're OK with NTSC.
    Order away!
  3. The Spaniard
    The Spaniard
    Jan 2, 2001
    1,105
    Walsall
    +80
    Thanks! Away I go then!
  4. figrin_dan
    figrin_dan
    Jan 9, 2003
    2,040
    +154
    Depends who did the mod really, My panny was modded in '99 and I could only go 'dual region'. If you did the 'solder splodge' hack, or was sold it as multi it'll be ok.
