Quick answer before order arrives
Discussion in 'Home Cinema Speakers' started by Gadjet, Jun 26, 2002.
  1. Gadjet
    Gadjet
    Aug 14, 2001
    411
    Wrexham
    +7
    I have ordered the new Pioneer AX-10. As well as 2 new front speakers which are floor standing, my current front 2 (tannoy mercury 2.5) will go to be the middle surround.
    Now the problem being that my room only being 12 by 13 ft, it will look a mess with speakers all around, furniture being totally out of place.
    My question is that this problem can be solved if I buy some satalite speakes and sell the rest. But, if I do this will the speakers be good enough to go with the amount being spent and the power of the Pioneer amp, will I loose quality of the sound?
    Please help so I can change my order.
    Much Appreciated, Phill
  2. MikeK
    MikeK
    I suppose it depends on the quality of the satellites you buy, but high quality miniature speakers aren't cheap.
    I don't know what speakers you have ordered - but Tannoy M2.5s, while decent enough budget speakers, probably aren't in the class necessary to get the best out of a £2k+ amplifier.
  3. planbeta
    planbeta
    May 20, 2002
    16
    Stourbridge
    Sounds to me that your amp will be begging for some M&K speakers!
    I have roughly the same size room as you, and I'm pretty sure that floorstanding, or even book shelf speakers will be too cramped for me - especially if I decide to go the 6.1 or 7.1 route. So I think I'm going to go for small speakers/satellites.
    I think one of the best small speakers is the M&K range if you can afford it, these should a perfect match for your amp and they are TINY too! From all accounts the quality of these surpass many floorstanding systems
    http://www.homecinemachoice.com/testbench/SpeakerPackages/M&K/M&KKSeries.shtml
    There's also the Raurk Vita 100 in the same price range:
    http://www.homecinemachoice.com/testbench/SpeakerPackages/Ruark/RuarkVita100.shtml
    Personally I'm not sure if I can afford the K Series yet, if not I don't mind settling for 7 kef eggs and rel sub!
