QUICK A5 question
Discussion in 'AV Receivers & Amplifiers' started by P3nZ, Dec 28, 2003.
  1. P3nZ
    P3nZ
    can somebody help with this quick question for a noob?
    Yamaha dsp-a5 + kef psw1000 = 1 single line sub output ?
    in short have sub and have amp although amp has a single line output for the sub and the sub has a double phono input ...
    which way should i wire this up and do i need a certain cable?
    cheers..
    ste
  2. bob1
    bob1
    Nov 7, 2002
    4,324
    Sheffield
    +129
    You can connect the one output to the sub left or right or you can buy a splitter which joins the inputs on the sub together, hope that helps.
  3. P3nZ
    P3nZ
    thanks for that....do you know where the splitters can be bought?
  4. bob1
    bob1
    Nov 7, 2002
    4,324
    Sheffield
    +129
    Try maplins, product code QN25C.
  5. P3nZ
    P3nZ
    cheers maplins it is then
