Quick 15" LCD TV / Monitor question, advice required ??
Discussion in 'LCD & LED LCD TVs Forum' started by foxmeister, May 11, 2003.
Tags:
  1. foxmeister
    foxmeister
    I'm thinking of buying an LCD screen for my bedroom, I have priced up 15" screens and with built in TV tuner I would probably have to spend £350.
    Would it be easier and cheaper for me to buy a Screen with no TV Tuner at a cost of approx £200 and then add a video, say £75 to act as the tuner ??
    Would I need to buy any other bits and pieces, I believe that the screens usually have built in speakers, would I need an Amp ??
    You're help would be appreciated, thanks ..
