Questions regarding my new 32PW9616...
Discussion in 'General TV Discussions Forum' started by Bicycle Boy, Aug 22, 2001.
  1. Bicycle Boy
    Bicycle Boy
    Aug 17, 2001
    41
    ..which was delivered this morning by John Lewis.
    They installed it and connected up my Skybox and Video.<br />The question I have is: My Skybox hasn't been connected up as an EXT source. If i go into the menu options and look at Digital Devices - it says none. I change it to EXT1 and get Sky in much better detail. Now I am getting a Tosh Sd210E DVD player next week. How do i then connect this up to a RGB EXT device as well ?
    Thanks for your help.
    I hope this makes sense. Please let me know if you need more info.
    Paul.
  2. Guest
    Hi Paul <br /> You will have to get an scart switching box you will probably get one from WithandWithoutWires.com<br />I had the same problem myself .<br />Your tv doesnt have componet video does it ? <img src="frown.gif" border="0">
  3. Bicycle Boy
    Bicycle Boy
    Aug 17, 2001
    41
    Even though I have 4 scart sockets, 2 of which are RGB ?
    regards
    Paul.
  4. Guest
    Hi its me again did'nt know you had two rgb capable scarts , you should'nt have a problem then , I supose I shouldnt have tryed to answer you're question as I am not familar with you tv.<br />Please excuse me <img src="frown.gif" border="0">
  5. Bicycle Boy
    Bicycle Boy
    Aug 17, 2001
    41
    Hey Alfred, all comments greatly received mate !
    Can any one who is familiar with this TV ?
  6. simondp
    simondp
    paul, i have the 28pw9616. I have my cable box connect to scart socket 2 (ext 2), dvd is s-video AND ext 1 (i get to choose ;o) My video goes thru the telewest box (i think!)
    No point in having your video connected to ext 1 or 2 which are the rgb inputs... use those for your sky and dvd (if it has RGB output, mine doesn't <img src="redface.gif" border="0"> (
    Best setup, if it does have RGB is probably dvd to ext 1, connect the digital out on the dvd to the digital in on the tv (coax), then in the menu select digital source as ext-1 plus digital. You'll then get rgb quality piccies and great dolby digital sound. Connect your skybox up to ext 2 (and make sure it's sending rgb - the tv will autodetect this)
    Doesn't the vcr connect via the skybox? if not, then connect to ext 3.
    Top tip - get some decent scart cables... trust me, i'm no expert but they make a difference. Ixos do some good ones, about £33 depending on length.
    Good luck.
  7. Bicycle Boy
    Bicycle Boy
    Aug 17, 2001
    41
    Thanks a lot Simon. I am doing what you suggested tomorrow ( I brought some decent cables this morning but am at work at the mo).<br />I got 2 IXOS Scart and one QED digital audio cable.
    Cheers all
    Paul.
  8. Bicycle Boy
    Bicycle Boy
    Aug 17, 2001
    41
    Simon as you have the same telly I have another question for you but i will start a new thread..
