questions regarding my lg rzpx11
Discussion in 'Plasma TVs' started by p0rt, Apr 25, 2005.
  1. p0rt
    p0rt
    Hi Guys,
    I have just setup my plasma and have a few questions if you don't mind.
    I have firmware version 5.13...is this version ok?
    Is the buzz normal...it's very quiet and not that noticeable
    When i change from one av channel to another the picture is displayed, immediately disappears for a split second then comes back again. Is this normal?
    Any help appreciated...
  2. DOCTOR_d
    DOCTOR_d
    Mar 12, 2005
    194
    Any other questions, let me know.... :thumbsup:
  3. p0rt
    p0rt
    Thanks very much for your reply.
    I am suffering some minor lip sync issues, it is only on some sky channels and dvds though. Is this related to firmware? i thought some ppl on later firmware versions were still suffering from these lip sync issues? I guess it could be my amp causing the problem anyway....
    The picture quality isnt great but i think that's due to cheap cables, i have some decent quality rgb scarts and components on order from tvcables.co.uk
    Cheers,
    Chris
  4. gazblue
    gazblue
    hi i have just brought a lg rz42px11 and have had issue's with lip sync probs etc. I rang lg who sent out engineers to fix this problem,When they came they said a complete card had to be replaced ? has anyone else had this done?
  5. Daddy k
    Daddy k
    Jul 19, 2004
    9,044
    coventry
    +1,345
    i would like my panel upgraded, so woundering what arrangements were they going to make ie do it at ur home, or take it away? leave u a replacement?
  6. gazblue
    gazblue
    hi the repair guys are due back today to fit the new card at home.they wanted to take the plasma back to the midlands for the repair,with no replacment set i said no way.hopefully this will fix the problems i have i will keep you posted once the new card has been fitted. :thumbsup:
