Questions Re: TH-42PW5BX
Discussion in 'Plasma TVs Forum' started by pwarren, Feb 24, 2003.
  1. pwarren
    pwarren
    Just took delivery of my new panasonic TH-42PW5BX plamsa panel on friday, and have to say i am blown away by it. I've went from a 24" sony widescreen tv to this, and you can imagine the culture shock due to the size. Got it from ivojo.co.uk, good service and good price and would not hesitate to recomend, no dead pixels and no transformer hum, so i'm over the moon.
    I have a couple of questions for you guys if you could help me out.
    I've turned the contrast and brightness down to zero and the picture is still great but what are the optimum settings? I'm a complete novice so any points would be appreciated, I know it's personal taste but don't really know what i'm looking for.
    The side panel bars for 4:3 pictures, what's the best setting to avoid screen burn?
    Noticed a bit of fuzziness, noise on some DVD's on bright colours, is this my settings? or the dvd player? Can I get rid of it?
    Cheers All
    __________________________________________________
    Kit: Panasonic TH-42PW5BX, Sky +, Sony 735 DVD, JS RGB>VGA Convertor, Van Damme component & VGA Cables
  2. jmack
    jmack
    you will be better off getting a setup disk like avia or get someone to calibrate it properly
    here is my settings if this helps
    pc imput ntl digital
    picture -13
    brightness -16
    colour temp .normal
    advance settings on
    w/b high r +8
    w/b high b +8
    w/b low r 0
    w/b low b +8
    i have them on usa english for fun
    the advance setting are like they are coz i had i bit of a green face problem on some people and copied someone setting on the usforums and it worked for me
    component imput
    cinema
    picture -3
    brightness -2
    colour +3
    tint+2
    sharpness 0
    colour temp normal
    all advance on 0
    gamma 2.0
    hope this helps
  3. pwarren
    pwarren
    Thanks for the reply jmack. I'll give those settings a go. By the way, where could i get one of these disks, and do they take you through the set up step by step.
    Paul
  4. joys_R_us
    joys_R_us
    To my limited knowledge Toshiba 42-16 is the equivalent to the Pana 4 series (the previous model). Hence the settings may not make any sense for your display. The 5 series display is technically quite different from the 4 series.
