davidnorthants
Hi was wondering if somebody could give me some help. I'm in the process of future proofing the house and flooding it with cable. I'm installing cat5 / cat6 / coax . I'm using the cat 5 for data, cat 6 for HDAnywhere, coax for loftbox SD tv in unimportant rooms e.g spare bedrooms.
I have basically run 2x cat5 / 2x cat6 / 1x coax to nearly every room in the house including bathrooms and all the cables will be terminated in the loft where all the equipment will be .
My questions are these
1. Is this enough cable to be able to Install HDAnywhere ?
2. Will I be able to put my sky box in the loft with the rest of the equipment and use the hdmi output to connect into the HDAnywhere matrix and then the RF2 output on my sky straight into the loftbox to distribute the sky around the house?
3. Am I right in thinking I can also add a digital aerial and fm aerial into the loftbox and send these down the same single coax to each location? Will I lose any quality in doing this ? Can I also buy 1 single face plate that splits this coax feed into fm and tv?
I appreciate any help people can give me.
Thanks David
Thanks David
