questions on cable
Discussion in 'Home Cinema Speakers' started by Paul.Scrivens, Mar 6, 2002.
  1. Paul.Scrivens
    Paul.Scrivens
    I have a Mission Cinema6 speaker pack and a Marantz SR4200. what is the best cable for connecting the amp to the Sub? I am currently using a Ixos 118-AV but this is only 1M. Also my sub has 2 inputs and I'm using a cheap Y connector to connect to the amp. will I be loosing quality? where can I get a better quality Y connector?
    I'm using QED Bronze Special Edition Speaker Cable for my other speakers. Is this a good choice?
    Also if I wanted to upgrade my speaker what would be the best route. I am thinking about replacing the Centre speaker with another from the Mission range.
    One last question I want to connect my computer Soundcard to my AMP. I'll make the cable myself. I was thinking of buying about 15m of Speaker cable put 2 jacks to connect to the L&R of the sound card and phono connectors on the other end to connect to the AMP. Where can I get these connectors?
    Any ideas?
  2. Electric Mayhem
    Electric Mayhem
    Mar 16, 2001
    10,627
    United Kingdom
    +2,233
    QED have a good name for cables so I dont think you´ve got bad stuff there.
    I´m using Chord Chrysalis for my sub cable, but you may find QED do a cable specifically for subs.
    If you´re looking to change your centre speaker stick within the Mission range as you´ll get a better tonal match than with another brand.
    Cant help you on the soundcard I´m afraid!
    cheers
  3. M.Joshi
    M.Joshi
    Oct 10, 2000
    249
    Harrow.
    +9
    If the output on your sound card is at line-level, the impedance will be different to that of a speaker output. You will need to use line-level cable for the ouput not speaker cable - use screened wire if you are running long lengths.
  4. Paul.Scrivens
    Paul.Scrivens
    It's a soundblaser live Soudcard. With L&R outputs. What type of cable do I need? where can I get it from?
  5. M.Joshi
    M.Joshi
    Oct 10, 2000
    249
    Harrow.
    +9
    Do the L/R outputs connect directly to the speakers or do they go through the sub first?
  6. Paul.Scrivens
    Paul.Scrivens
    They connect directly to the computer speakers at the moment.
    I want to connect them to the amp. What cable do I require?
  7. M.Joshi
    M.Joshi
    Oct 10, 2000
    249
    Harrow.
    +9
    Are the computer speakers powered or non-powered i.e passive?
  8. Paul.Scrivens
    Paul.Scrivens
    Computer speakers are powered.
    What cable do I require? I'll then order 2 stereo jacks to connect to my soundcard and 2 phono plugs to connect to the amp - will this work?
  9. M.Joshi
    M.Joshi
    Oct 10, 2000
    249
    Harrow.
    +9
    Provided that the outputs are line-level, you should have no problem. You will need to buy standard line-level cable, depending on your budget, try and go for a reputable name.
