questions for vierra owners.
Discussion in 'Plasma TVs Forum' started by GalacticaActual, Aug 23, 2004.
  1. GalacticaActual
    GalacticaActual
    Jun 1, 2004
    5,938
    Galactica C.I.C.
    +283
    Hi there. am leaning towards getting a 37" vierra after much searching ,
    I would like to know the following ,if any out there can help please.
    do the vierra plasmas suffer from the same problem as panasonics acuity sets with combing on fast movements. I have seen one on display recently and when a still image suddenly moves it looked as though a comb was going through the persons face.
    Are the verras 100hrz flicker free ,progresive scan or 50 hrz please?
    How easy is it to adjust overscan on the verra plasmas, Ie do you have to use the service menu or can it be done from the standard user menus?
    Many thanks to anyone that can help me make up my mind. :thumbsup:
  2. GalacticaActual
    GalacticaActual
    Jun 1, 2004
    5,938
    Galactica C.I.C.
    +283
    Sorry to be impatient, I know I only posted this morning but, no one on here has a verra?? :confused: :confused: :confused: :)
  3. Steve_P
    Steve_P
    Jul 3, 2004
    1,338
    67
    +142
    My TV seems fine on fast moving scenes or large pans left or right with the camera. The images on football matches look great to me which is a shame as I can't stand the game so never watch it :clown: :blush:
    The Vieras are progressive scan displays so any signal is de-interlaced before being fed to the panel. Having said that, some owners here have posted that they have noticed flicker on these sets (or any Panny series 6 SD panel) but it depends on how sensitive your eyes are to flicker. I've actually looked out for this phenomenon and can't see it on my set despite my best efforts :thumbsup: Some see it, some don't, best to view for yourself and make up your own mind.
    Sorry I don't understand your question about over-scan but then I am a relative noob to the world of plasmas but there is a standard setting where you can turn off/on 3D-Comb filtering on analogue signals and toggle off/on P-NR noise filtering and select one of off/low/med/max for MPeg artifact filtering.
    Hope this helps.
    S.
  4. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    i think you can adjust overscan from picture menu, will check this PM mate.
  5. GalacticaActual
    GalacticaActual
    Jun 1, 2004
    5,938
    Galactica C.I.C.
    +283
    hey there hornydragon, always nice to see one of your posts. I have had so much info of you and MAW recently that I feel i know you :D :)
    Sorry to be so picky about all these questions but this purchase has to be as near to perfection as possible , I am afterall a fussy bas :censored: d
    oh and steve _p thanks for the info on your verra as well. much apreciated :)
    anyone out there with a verra who would like to add anything would also be apprecated.
    Thanks. dave. :)
  6. big dave
    big dave
    Got mine last thursday, couldn't be happier (unless it came with a crate of beer and two lap-dancers).
    I too am a noob, but I can say that during watching footie I do not gat the "combing" that you ask about. Had a Philips and the great game was unwatchable.
    Get one. As Tony would say "they're greeeeeeaaaaaaaaaaatt"
  7. BruZZi
    BruZZi
    May 9, 2004
    28
    Service Menu only.
  8. GalacticaActual
    GalacticaActual
    Jun 1, 2004
    5,938
    Galactica C.I.C.
    +283
    Ok , so how do you get in to the service menu and what should you avoid doing while there?
  9. GalacticaActual
    GalacticaActual
    Jun 1, 2004
    5,938
    Galactica C.I.C.
    +283
    sorry , dont like to bump threads but does anyone know how to get into the service menu on the 37 viera??? :)
  10. ums69
    ums69
  11. BrynTeg
    BrynTeg
    Sep 9, 2000
    15,092
    137
    Cardigan Wales
    +1,952
    with the viera what is the best way to connect to dvd player.rgb scart??can someone recomend a good scart at an affordable price,my plasma is due to arrive next month.
  12. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    component if you have it mate, might need a scart as well for extra stuff, audio aspect switching etc.
  13. Steve_P
    Steve_P
    Jul 3, 2004
    1,338
    67
    +142
    Depending on the capabilities of your DVD player, the best connection on the Viera is component (3 RCA phono plugs, red green blue) and best to feed it a progressive scan signal. If your DVD player isn't capable of component output (progressive or interlaced) then the next best option is RGB SCART. :oops: Apologies to David for going :offtopic:
    S.
  14. BrynTeg
    BrynTeg
    Sep 9, 2000
    15,092
    137
    Cardigan Wales
    +1,952
    thanks for your advice and sorry for butting in
  15. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    You should get a free DVD-Recorder DMR-E55 which has component and progscan for free with plasma!
  16. BrynTeg
    BrynTeg
    Sep 9, 2000
    15,092
    137
    Cardigan Wales
    +1,952
    what sort of money do they ask for one of those,buying the plasma from my mate who owns his own panny shop.
  17. GalacticaActual
    GalacticaActual
    Jun 1, 2004
    5,938
    Galactica C.I.C.
    +283
    Ok. I can get into the service menu. I can use the red and green buttons to see things like r drive and b drive, subcontrast ect there is no option to adjust hamp and vamp or horizontzl and vertical postion. what am I doing wrong. the overscan on the vierra is quite bad and is the only thing spoiling a great piece of kit. Please, please, please, can anyone help :)
  18. GalacticaActual
    GalacticaActual
    Jun 1, 2004
    5,938
    Galactica C.I.C.
    +283
    come on guys. gonna goto bed soon and would love to sort this it before it starts to bug the hell out of me :laugh:
  19. bobbles
    bobbles
    I have never even been into the service menu, what does it allow you to do?
    I have never noticed any problem with fast moving objects. The only time I have never been 100% happy is long shots of football do not seem to be perfectly in focus.
  20. GalacticaActual
    GalacticaActual
    Jun 1, 2004
    5,938
    Galactica C.I.C.
    +283
    Right managed to get in to the service menu. then you have to swithch to channel 99 and press hold to bring up service menu 2. you can adjust hamp and vamp in this menu but adjusting them does not do what hamp and vamp does on a stanard tv. all it does is move the picture from left to right and up and down like the vpostion and hpostion. also you can not change channel to av4 to use a test pattern on the dvd player while on channel 99 in service menu 2. anyone with any idear what I am doing wrong? :confused:
