Questions for Kef Q4 owners
Discussion in 'Home Cinema Speakers' started by Malky1903, Dec 13, 2004.
  1. Malky1903
    Malky1903
    Jul 2, 2003
    1,908
    48
    Aberdeen
    +64
    So I'm the proud owner of a brand new pair of Q4's, thanks to the other half :D but I have a couple of questions.
    Bungs in or out?
    Can the plastic protectors on the speakers be removed so I can connect banana plugs? Can't see a way of removing them.
    Errrm. That's all.........for now.
  2. bobbypunk
    bobbypunk
    completely unscrew one terminal, then use pliers to pull the bung off, then rescrew.
  3. Tejstar
    Tejstar
    Dec 4, 2002
    22,517
    London
    +1,005
    I've kept the bungs out for now, but I'm going to experiment properly and then make a decision.
    Regarding the banana plugs issue, I'm not sure. My speaker wire isn't terminated so it's not an issue for me!
  4. Mr Cat
    Mr Cat
    Jul 23, 2003
    2,190
    Weardale
    +57
    they're great speakers - good choice!
    I've got the bungs out....
    I bought mine seconds hand - 200 quid with an hours use! so I guess the plasitc protectors were already out asd I can use banana plugs easily...:)
