Questions about soldering RGB Lead
Discussion in 'Cables & Switches' started by Sim1968, Jun 29, 2004.
  1. Sim1968
    Sim1968
    I've got a bit of a problem with an RGB lead that is chased into the wall. Its attached to my plasma on one end and the DVD on the other. I used an IXOS XHV704-100 5m Component Video Cable. The Red lead has come out of its plug and my futile attemts to solder back on have resulted in failure. Does anybody know the correct config with the plug? Do I have to use a special type of solder :confused: ? Alternatively are there any AV geniuses based in the Essex / East London area who could visit me? I'll pay!!!..........One final question, I have asked IXO if they could sell me just the plug but I've had no reply, anybody know where I can buy the plugs seperately??
    Thanks in anticipation
    Simon
