Questions about RCE dvd's
Discussion in 'Movie Forum' started by pauld, May 27, 2001.
  1. pauld
    pauld
    It's only used on region 1 discs and Columbia tristar use it (although I read somewhere that they have now abandoned it) , MGM have just started to use it aswell. Not sure if any other distributor uses it, can anyone else help?
  2. Koosnaff
    Koosnaff
    Jun 1, 2001
    79
    9
    Kent, UK
    Hi Eros
    Not sure if this helps, but I have a Wharfy 750S, and Hollow Man R1 is RCE, but it plays fine so I should imagine that it would be ok on the 750. Best bet is to see if you can borrow a R1 RCE disk and see if it works. If it does, assume all RCE disks will work ...
  3. eros
    eros
    1. Is this system just used on region 1 titles?
    2. What film studio's are implementing this system on dvd's?
    3. Will my wharfedale 750 (original model) have problems with these dvd's? If so, will it be region 1 & 2? (assuming that RCE is used on R2 disks).
    Cheers!!
