Questions about Panasonic TH-50PHD6
Discussion in 'Plasma TVs' started by Lizzard, Dec 28, 2003.
  1. Lizzard
    Lizzard
    I am considering buying the TH-50PHD6, but i do not know what scaler i should go with it.....
    1.Should i buy the Lumagen, the Iscan HD, or any other scaler?
    2.Which one is the best for this plasma?
    3.Does this plasma only come in a black frame? or can i get it with a silver frame?
    4.Is the Pioneer DV-868AVi-S a good choice for this plasma if you want a good DVD player?
    5.Do i need a scaler if i buy the above Pioneer DVD player or will i improve the picture even more if i also add the scaler?
    6.What is the status regarding the DVI module to this plasma? does it work with both 50/60Hz?
    7.How about warranty on the Panasonics? do they have European Wide warranty or limited only to the country you are buying it from? eg importing from U.K
