Questions about iPhone 5 av adapter
Discussion in 'iPhone Forum' started by aymank, Aug 7, 2013.
Tags:
  1. aymank
    aymank
    Apr 26, 2006
    2,936
    83
    Liverpool
    +196
    Will it let me out put TV catchup app to a TV ? Also does YouTube work ?
  2. williamus
    williamus
    Feb 6, 2009
    929
    46
    Birmingham
    +142
    If you're asking about the Lightning/HDMI adaptor, the answer's yes on both counts. It also works with Filmon.TV and Eurosport Player but not Skysport TV.
    It uses a prodigious amount of juice to run the 5V HDMI connection, though, and you really need to have it connected to a charger at the same time. It can get quite hot too.
    A much better solution (as I'm sure you know) is the ATV3 via the personal hotspot and mirroring.
