Ash007
Could anybody answer these setup questions for me. I couldn't find the answers in the newsgroups
Which is more prevalent - digital coax or digital optical? Im curently getting cables for my current DVDplayer, which has both outputs, but when i eventually change my DVD player I don't want to be restricted by conections or have to change cables. As they do the same job with the same quality with one having no advantage over the other, is one likely to become the standard whilst the other one fades away, or do you think most DVD players will continue to have both coax and optical?
I notice you can daisy chain toslinks. Would you get a degregration of quality if you linked 3 or 4 to get a long 15-20 metre run?
Connecting up a YUV conection, can you just use 3 composite phono type cables or are the 3 cables all different. I have several old composite phono cables around (them red and white analogue audio stereo leads ). Are these leads fine or do you need special YUV cables or are they the same.
Is YUV another name for YPbPr?
Can Scart RGB not do progresive scan?
For progresive scan do you need a special progresive scan tv, a special progresive scan player des the DVD need to be a progresive scan disk?
Cheers for any help with these matters,
Ash
Ash
