Question
Discussion in 'Projectors, Screens & Video Processors' started by Gadget Daddy, Apr 2, 2005.
  1. Gadget Daddy
    Gadget Daddy
    Feb 19, 2005
    3,427
    83
    Stockton on Tees
    +174
    Im looking for the best solution to improve my viewing experience
    H/w
    LG PX11 Plasma
    Digifusion PVR
    Modded Xbox
    Denon 500SD DVD Home cinema
    Mainly watch Freeview/PVR and Xbox
    Choices
    JS Tech RGB to Component (YUV) Video Converter
    JS Tech RGB to VGA video convertor
    Zinwell BLS-2000 DVI Briteview Interlacer/HDTV Scaler
    Zinwell AVT 3700
    Also could you please tell me which is the best Zinwell?
    Pete
  2. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    26,760
    The Borders
    +3,088
    Hello PeteB 2000
    Neither of the Video Processors you list (the second one is not by Zinwell :)) have Inputs for an RGB+Composite Sync signal; which is not ideal for the majority of Freeview or SKY owners.
    As your LG Display already has a more than decent on-board Faroudja DCDi Deinterlacer your really looking at something more flexible/powerful than these entry level video processors if your going to make a worthwhile upgrade.
    Your Display has RGB equipped SCART sockets so again very little if any advantage to be gained by adding a JS Technology converter to your set up.
    If your wanting to optimise your system without spending near 1K on a decent Video Processor I'd be looking to ensure you had the best video interconnects between source and Display and have someone come to you to calibrate your Display (£250).
    Best regards
    Joe
  3. Gadget Daddy
    Gadget Daddy
    Feb 19, 2005
    3,427
    83
    Stockton on Tees
    +174
    thanks Joe for your wise words
    Pete
