Question
Discussion in 'Subwoofers' started by dakid, Feb 2, 2005.
  1. dakid
    dakid
    anyone know a good cheap sub i can get to hook up to my comp :lease:
    :offtopic: but what the fudge is SQ??????
  2. theo cupier
    theo cupier
    Sep 18, 2004
    1,660
    63
    Amersham, Bucks
    +113
    How cheap is cheap?
    What outputs does your comp have?
    What the flip does what the fudge mean?
  3. dakid
    dakid
    im trying to stay around $50
    my comp the standard 3.5 mm plug
    what the fudge=what the ****
  4. PJTX100
    PJTX100
    Dec 21, 2004
    8,140
    +564
    For that price you are probably better buying a decent curry for one of your mates and have him sit in the corner of the room...PJ ;)
  5. dakid
    dakid
  6. PJTX100
    PJTX100
    Dec 21, 2004
    8,140
    +564
  7. Mroizouk
    Mroizouk
    Jan 11, 2005
    336
    London
  8. theo cupier
    theo cupier
    Sep 18, 2004
    1,660
    63
    Amersham, Bucks
    +113
    Given the success at my last attempt at sarcasm (perhaps that should be sarchasm?) I won't make a 'helpful suggestion' involving purchase of a sturdy cardboard box and some cling film / saran wrap as a $50 subwoofer (although you could use the leftover $ to buy a really good wooden spoon to hit it with)...
    I'm assuming that you want the subwoofer for your PC just to have a bit of extra thump when playing PC games, rather than as part of a high-end Media Server type scenario... If so, I don't think most of the people here will have too much to impart of use (correct me if I'm wrong). Ask us about a $500 (or $5000) subwoofer and we can probably give you an armload of useful information to leave your head spinning this way and that.
    At your price point, you'd be looking at Creative Labs or perhaps Altec speakers and they are all pretty much the same really. Best you can do is head down to your nearest computer store (or Staples or WalMart or whatever) and take a look at what they've got. Maybe even ask someone to set one up for you so you can have a listen. But bear in mind that the sound in their warehouse-sized store will be very different from what you get in your room.
    Buy something based on what it looks like, safe in the knowledge that for $50 what ever choice you make is going to sound about as good/bad as any other choice you could have made.
    HTH
    TTFN
  9. dakid
    dakid
    $5000 for a sub im not talkin bout an amp either your shopping at the wrong store or you buyin some really special sub i got a 12 solo x in my car for $700 it does not have really low bass (my freind install it) but it sound jus fine n i got a cheap ass amp pushin it right now.
    Edited by Ian J for language
    :oops: :censored:
  10. tom_painter85
    tom_painter85
    Jan 19, 2005
    201
    Exeter
    click here for some cheap PC subs on amazon.com. they won't be wonderful but its worth a try.
