Question regarding using 52x CD-R media on 8x CD-Writer
Discussion in 'Desktop & Laptop Computers Forum' started by reservoir51, Apr 2, 2005.
  1. reservoir51
    reservoir51
    I'd be grateful if someone could answer the above query.
    I've got an old 8x CD-Writer which is still wonderfully functional. However, since CDR media these days have moved on to 52x, I was wondering if such 52x media could work on older CD-Writers such as mine writing at speeds significantly slower than 52x (i.e. 8x in my case). I believe manufacturers of CD media usually state that their high-speed media shouldn't be used on 1x CD-Writers, but what about speeds of 4x or above?
    Cheers,
    reservoir51
  2. dekoded
    dekoded
    Oct 30, 2004
    893
    Blackpool
    +45
    I don't see it being a problem, after all most burning software allows you to choose a slower speed to burn the cd/dvd at, in fact it is normally better to burn at slower speeds as it can make the burned 'pits' more defined which means less error correcting needs to be done when reading the disc.
    The cd multichanger in my car refuses to play cd's burned at high speed !, but if I burn slower they play fine :smashin:
  3. reservoir51
    reservoir51
    Ok, thanks for the info Johnnie. :smashin:
    Cheers,
    reservoir51
  4. dekoded
    dekoded
    Oct 30, 2004
    893
    Blackpool
    +45
    no probs :thumbsup:
