Question regarding the Humax 8000T
Discussion in 'Digital TV & Video Players & Recorders' started by murtagh, Dec 5, 2004.
Tags:
  1. murtagh
    murtagh
    Thinking about buying the Humax 8000T however got a question regarding updates, when you install the most up to date version does it contain, all previous updates (Guessing it will, but like to be sure).
    Also guessing that when I get my box I will have to download and install the most up to date version via the pc. - I'm guessing that there is no weekly broadcast of the updates !!!!
    ta
  2. JamesE
    JamesE
    Jul 30, 2004
    48
    North Lincolnshire
    I bought mine 30 July and it was well up to date. It had the full EPG. There was one small update which altered some default settings which I did off air when it came out. You have to keep your eyes open in forums etc. for when there is an update - you don't find out any other way (I do NOT leave it on standby - I switch it off when out of use)
