Question regarding 3:2 Pull down detection
Discussion in 'Projectors, Screens & Video Processors' started by halau, Sep 10, 2001.
  1. halau
    halau
    Hi there,
    I am new to AV forum and am thinking of buying a progressive DVD player.
    I have a question regarding 3:2 pull down detection.
    Currently, I have a progressive-capable rear projection TV which doesn't have 3:2 pull-down detection/compensation.
    If I have a progressive DVD player with 3:2 pulldown detection & compensation capability, is it going to help the picture ?
    Or to enjoy the good movie quality (where 3:2 pulldown is in effect), both the TV/monitor and the progressive DVD player have to have the 3:2 pulldown detection & compensation feature ?
    Any reply is greatly appreciated.
    Thanks !
    <br />Andy<br />Toronto, Canada.
  2. halau
    halau
    Oh, I don't know if it is relevant. I forgot to mention that my rear projection is Toshiba 40H80(Canadian/US model) which is probably similar to 40PW03B in UK.
    Thanks again !
  3. Gordon @ Convergent AV
    Jul 13, 2000
    14,207
    +3,042
    Andy: In your situation the answer is that a progressive DVD player with 3:2 detection will make a huge difference. Only with film based DVD's though.
    The ability to re-construct the original frames of the movie and then replay them in a 3:2 sequence will result in a lot less artifacting. It should be a very worthwhile improvement.
    Where are you in Canada?
    Gordon
  4. RichardA
    RichardA
    Halau,
    As Gordon says, using a Progressive Scan DVD player with 3:2 detection will give you a significant improvement.
    you do not need 3:2 detection in the TV set as well as it is only required where you go from interlace to progressive scan (i.e. bringing related fields back to their correct frames)- in this case in the DVD player. Once the image is in progressive scan frames are frames and no further processing is necessary in your case.
    I hope this helps
    Richard
  5. halau
    halau
    Thanks for your reply, Gordon and Richard.
    So the TV just treats the frames as frames, regardless of whether 3:2 pulldown applies or not.
    Hmm, I would keep my eye on some progressive DVD players.
    Since there is still uncertainty b/w DVD-audio and SACD as far as which is gonna to dominate the market or they will share the market in a different way, I will just hold on to purchasing a new DVD player.
    We don't have a winner among DVD-RW, DVD+RW and DVD-RAM either..
    At least I would wait for a player with progressive scan, HDCD, DVD-audio and/or SACD features.
    Of course, the price is also a concern. I am trying to look for one in mid-prices range, DENON DVD-2800 looks good but it lacks DVD-audio or SACD capability.
    Gordon, to answer your question, I'm in Toronto. <img src="smile.gif" border="0">
    Andy
  6. Gordon @ Convergent AV
    Jul 13, 2000
    14,207
    +3,042
    Andy,
    I have prospective in-laws in Burlington!
    If you get the chance go to London and see Ric Ho at London Audio. They were the best a/v dealer I found in my visit to Toronto this summer.
    Gordon
  7. halau
    halau
    Hi Gordon, Sure, I will. Thanks for telling.
    Hope you had a good time during your Toronto's visit. <img src="smile.gif" border="0">
    And I've read a few Home Cinema magazines recently. Good resource.
    <br />Andy
