question re rgb only scart
Discussion in 'Cables & Switches' started by micks_address, Jun 17, 2005.
  1. micks_address
    micks_address
    Nov 29, 2001
    4,465
    83
    Dublin
    +218
    Hi folks,
    About to purchase an RGB only scart lead and i have one question
    Its to connect sky plus to my tv and i'm currently using the standard supplied scart which carries the signal to switch the picture format when it changes from wide to 4:3 etc. (i think the signal is carried on pin 8?)
    Anyway what i'm wondering is will the RGB only scart still carry this signal to the tv or will i loose the auto switching? Is pin 8 wired on a RGB only scart?
    Thanks,
    Mick
  2. Londondecca
    Londondecca
    Dec 21, 2003
    2,080
    +96
    I think it is pin 16, but it is a long time since I looked at the scart lead pins. In anycase, you should be fine with a RGB scart
