Question re bulk standard SOny trinitron
Discussion in 'General TV Discussions Forum' started by nunew33, Jun 25, 2002.
  1. nunew33
    nunew33
    Jun 5, 2002
    1,736
    41
    Lytham St Annes, where people are put out to grass
    Not sure if this should be here or under AV Amps will post in both.
    Set up the Marantz SR5200 last night. Connected TV to TV in via Audio scokets at rear of television which is a bulk standard Sony trinitron 3:4 set somthing like a KV29F2 or F3. The sound is dreadful (distorted ) if I watch terrestrial channels yet if I play the DVD and pick up audio via the TV the sound is clear. Just wondering if the audio outs on the TV are preouts or not. If they arent is there anyway I can use them or will my only route be to take a line off one of the scarts (which will be tricky as they are both in use and only one has out
    Sound is clear from terrestrial channels if I pick them up via the Video, I was hoping to use the TV for analog source so that I could get sound regardless of the input source to the TV (eg one point for VCR, TV and On digital rather than 3 seperate connections to Amp)
  2. simon1
    simon1
    Jul 7, 2001
    918
    28
    Teesside
    +58
    I had the opposite problem to you - sound output from tv was too quiet.
    Sony tv's have variable phono outputs. You need to adjust the 'headphone volume' on the tv's menu. Daft idea or what?
  3. lynx
    lynx
    Jan 20, 2002
    4,652
    It always rains.
    +302
    from forum rules and guidelines:-
  4. nunew33
    nunew33
    Jun 5, 2002
    1,736
    41
    Thanks lynx. Problem solved, reduced headphone level has eliminated distortion
