Question re biamping with AVR250
Discussion in 'AV Receivers & Amplifiers' started by JHAz, Feb 3, 2009.
Tags:
  1. JHAz
    JHAz
    Feb 3, 2009
    11
    3
    Greetings from a new guy on this forum.
    I recently acquired an AVR250 to go with my DV78, and am using it to biamp my Magnepan speakers. The sound is very good. A topic for another day is trying to sort out whether I prefer music through the analog connections or using the AVR250s internal DACs. Each seems to have strengths.
    But my question today is more prosaic, and I'll get to it. I wired channels 1 and 2 to the treble panels of my Magnepans, and 6 and 7 to the bass. Then after tucking everything into my rack, I looked at the manual and noticed it has a drwaing showing channels 1 and 2 for the low end, and 6 and 7 for the high.
    My expectation is that it makes no difference. But maybe I am missing something. Is there a reason I should pull everything back out and switch the connections to match the manual?
    Thanks for any advice
    Jim
  2. Badger0-0
    Badger0-0
    May 30, 2005
    20,601
    Spaghetti Junction (really)
    +1,923
    Good question :smashin:
    I'd guess it makes no difference too and it's probably just to help clarify things, so you don't stick 2 positives into the same speaker.
