hhargreaves
I’ve been considering upgrading my current system from a Samsung QE65Q800T to the Philips 65OLED856, as I want to be able to use my Xbox Series X at [email protected] with ambient light.
For some context, I’m currently using a Philips hue sync box, which limits the input to [email protected] (HDMI 2.0) - so I wanted to double check it the ambient light still works on the 65OLED856 when the input signal is [email protected], was also curious if the ambient light works with everything (I.e. terrestrial tv, Netflix etc.).
Thanks in advance!
Thanks in advance!
