Question on Yamaha RXV1500
Discussion in 'AV Receivers & Amplifiers' started by Apprentice, Jul 28, 2005.
Tags:
  1. Apprentice
    Apprentice
    Jun 11, 2005
    The Zone 2/3 indicators on the display are always ON although their setting in the SOUND MENU is OFF. It appears that there is nothing I can do to get rid of them, but I remember them once being off, and this without doing anything special. I would appreciate any experience you have in this respect so that I can assess where the problem comes from (me not knowing to set it up or some kind of failure of the receiver).
    Thank you for your help on this.
    Valentin
    Yamaha RXv1500 on Monitor Audio B4/Central/B2/ASW100
  2. Krysten CTR
    Krysten CTR
    Jun 4, 2005
    3
    To turn off the Zone 2 & 3 do the following.
    1) Slide the switch on the side of the handset to 'Source'.
    2) Push the up arrow button on the right of the little lcd screen.
    This will light up and show zone 2
    3) Push the standby button (Top row second in from right)
    Zone 2 on the AMP will have turned off
    Repeat from stage 2 to bring up Zone 3 and turn off the same way.
  3. cliveuk
    cliveuk
    Aug 20, 2004
    524
    28
    Folkestone, UK
    +45
    i have the same problem and that does not work for me... i cant get zone 2/3 on the remote
  4. chris.
    chris.
    This is the correct proceedure but you MUST setup the remote to control Zone2/3 as seperate devices first:
    Push and hold learn until SETUP appears
    The display on the r/c shows L:XXX (where XXX is a device duch as DVD or TV)
    Using the scroll righ key, scroll until L:AMP is displayed then press enter.
    2000 is displayed on the r/c display
    Press 2 0 0 1 enter then press and repease LEARN with a pen
    NOW when you follow Krysten CTR's instructions you will have a different result!:thumbsup:
    Also, if you now only power on the amp from the r/c, zone 2/3 will only come on when you tell them to by using the newly programmed zone2/3 controls!
