Bernard Barnett
Established Member
If you take the 930 out of the box and connect it via component, do you get a picture so you can access the menus? Or do you (as I had to do with my Arcam) have to connect via scart, get into the menus, select component, and then plug in your component cables?
(Incidentally I'd like to thank Cybersoga for his very full account in another 930 thread of his findings in setting up the player. The question I've posed above is just about the only one he didn't answer!)
