Question on Roku Soundbridge & Netgear WGR614 v4 compatibility
Discussion in 'Headphones, Earphones & Portable Music' started by Chris1234, Mar 24, 2006.
  1. Chris1234
    Chris1234
    Hello,
    I am looking at buying a Roku Soundbridge M1001.
    The only thing keeping me from doing so at the moment is that according to the Roku website, there are issues with my wireless router (Netgear WGR614 v4).
    Looking on their forum, however, there are a number of posts suggesting that this issue was fixed in a newer software release. This doesn't, however, stop the company website from still showing it as a problem router!
    Does anyone have this configuration working?
  2. Chris1234
    Chris1234
    Hi All,
    In case anyone else has the same question in the future and comes across this thread in a search, I took a risk anyway seeing as the supplier (www.easyishop.co.uk) said they'd take it back if it didn't work.
    In short, this config works perfectly. Methinks Roku's technical pages lag a release or two behind their software!
